Man!!!! Broke the breather fitting where it goes into plenum
This is really getting fun now!!!!
I am inching ever closer now but keep stumbling.
I just broke the fitting from the plenum that attaches to the right side breather hose.
Anyone had any luck finding a fitting anywhere or rigging anything up? I called the dealership and they couldn't find a part #.
I really need to get this thing done.
I broke both the breather hose fitting you described and the brake servo vacuum pipe while lying on the engine changing the plug wires. I just bought a brass version at Lowe's that was an exact duplicate of the breather hose fitting, both the hose barb end and the threaded end. Just take your broken pieces to Lowe's, The Home Depot, or your local Ace or mom and pop hardware store and look in the plumbing section. Mine was under five bucks, I recall. I just wrapped the threaded end with Teflon tape and it screwed right in.
i broke both the breather hose fitting you described and the brake servo vacuum pipe while lying on the engine changing the plug wires. I just bought a brass version at lowe's that was an exact duplicate of the breather hose fitting, both the hose barb end and the threaded end. Just take your broken pieces to lowe's, the home depot, or your local ace or mom and pop hardware store and look in the plumbing section. Mine was under five bucks, i recall. I just wrapped the threaded end with teflon tape and it screwed right in.
