Man!!!! Broke the breather fitting where it goes into plenum
Old Apr 14, 2011 | 09:12 AM
Go to a Napa store, they will have good brass fittings.
Old Apr 14, 2011 | 09:23 PM
jkid's Avatar
They are a pretty common plumbing fitting. They had them in the check-out isle at harbor freight last week, talk about random.
Old Jul 8, 2012 | 03:53 PM
FightOnUSC79's Avatar
Just broke this, but as described int came off flush, How the heck do you get it out of there to find a brass replacement? If I cannot get it out in one piece sizing it will be a PITA.
Any help is appreciated
Old Jul 8, 2012 | 04:29 PM
Pulling a plastic threaded pipe out is too simple, work at it, you can do it.
Old Jul 8, 2012 | 05:52 PM
I guess the answer I was looking for was in regards to just yanking it out will not start some god awful sequence of events.
Old Jul 8, 2012 | 08:23 PM
mln01's Avatar
How about jamming an extra-large screwdriver inside and unscrewing it? Or maybe an old knife if you don't have a screwdriver big enough? Or you could always by an EZ-Out if the first two ideas don't work.
Old Jul 9, 2012 | 09:10 PM
Went with the old knife method From my experience, an old knife will fix most problems..
THank you
Old Oct 1, 2018 | 03:05 PM
Discorama's Avatar
I have the same broken part (ERR6880/LKL000080) and don't want to spend $18 on a plastic part that might break again but looking for the brass one. Taking it out without having a replacement is a bit risky for me, so I need to get the brass fitting before I cut the plastic fitting into pieces or melt it down with a torch. Does anyone know the thread size and diameters or a part number for the brass fitting? I couldn't find that info here nor anywhere else in the Interwebs. Thanks.
Old Oct 1, 2018 | 03:13 PM
Best4x4's Avatar
Any auto store will have a 1/4 threaded nipple with a 3/8 barb on it (very common with air tools), lowes, home depot, tractor supply company, or slap in an FV308 PCV.
Old Oct 1, 2018 | 03:31 PM
OverRover's Avatar
Yep, Home Depot or Lowe's all day...….
