Manual correct for brake bleed??
Old Mar 4, 2020 | 06:36 PM
whiterabbit's Avatar
Default Manual correct for brake bleed??
The manual seemed weird starting at the front and working towards the rear of the truck, is it correct?? Also I need to jump pins 3 & 5 on ABS relay 10 to power bleed the module correct? I got mushy brakes, just replaced the reservoir and the 3 amigos have been present since I bought the truck.
Thanks,
M
Old Mar 5, 2020 | 09:40 AM
zuke's Avatar
I always thought it was backward. But just to be sure I did it per the RAVE then redid it starting at the furthest point (RR). I just use a vacuum bleeder. I think (and I may be wrong) that jumping the relay risks damage to your ABS unit.
Old Mar 5, 2020 | 09:57 AM
whowa004's Avatar
I just went back to front and no power bleed and no problems.
Old Mar 5, 2020 | 10:08 AM
JUKE179r's Avatar
Jump the ABS relay for only 10-12 seconds then giving it a rest for a couple of minutes at each corner.
Old Mar 5, 2020 | 08:52 PM
Went front to back and back to front to use up the large container of brake fluid. I did bleed with the ABS and a jumper/trigger. I still have alot of pedal travel but I need to mic the rotors, they might be worn a lil' too thin.
JettsRover
Jul 14, 2018 08:55 PM
jamestfl
Jan 16, 2017 02:29 PM
dz5bxm
Dec 6, 2015 07:40 AM
bostongrun
Oct 30, 2015 11:33 AM
KeizerRover
Mar 15, 2008 01:24 PM
