Manual and Sport Lights Come On in 03 Disco
![Exclamation](https://landroverforums.com/forum/images/icons/icon4.gif)
Lately both the lights come on when I shift into gear and do not come to complete stop. Now it's getting worse when my wife is driving it. She had to stop three times today, shut off ignition and startup to reset. Any help, we have a appt. scheduled with dealership at 11 Eastern time.
My daughter has had her 2004 Disco for about 2 months, and it has just started with the manual and sport mode flashing lights. Sometimes it clears when restarting the vehicle, but usually the flashing lights persists once shifted into drive. Vehicle seems to stay in 3rd gear as well.
Short of going to dealer, what can be done to check or resolve the issue?
Thanks
Thanks
No, no trip to the dealer needed.
You have low battery voltage.
Take it to another auto parts store and try again.
Watch them test your battery and alt.
You can watch the machine they use, the alt needs to be putting out at least 13.5 volts, thats the min.
Make sure they load test the system too.
All the dealer is going to do is sell you a new battery and alt.
You might have a loose belt, bad belt tensioner or a bad battery or alt.
All of these are easy DIY jobs and the most expensive part of them all is the alt, $200 at AutoZone.
I just had my battery and alt tested and here are my results...
Battery: "good - recharge" (?), voltage =12.64v, measured 556cca, rated 600 cca
Alt: "no problems", no load =13.64v, loaded =13.43v
I'm going to hook the battery up to some little charger we have overnight...but what do these numbers tell me? If it isn't the battery or alt, what's else?
P.S. my "M" and "S" lights have been flashing the last 4 times when started up, and even during these tests and the 1/2 mile drive to and from Advance.
Thanks.
Thanks.
And yes, the guy only told me and read exactly what the machine told him. Parrots I say. Sucks that I need a new alt though...any tips on best value?
