Manuals on Rave CD
RE: Manuals on Rave CD
Hi Nynole,
An .iso image is a only an image of a disk. So in other words, you need to burn that image (not the iso file itself) to a cd. Once you do that you should see the "setup.exe" file on the cd. So depending on what software you use to burn cd's, you would open that and select burn cd from iso image and burn it to a a blank cd and then run the setup file. Any questions or help just holler.
Bob
Bob
