Mass Air Flow
Old Nov 7, 2008 | 09:25 AM
akc's Avatar
akc
Default Mass Air Flow
Does anyone have an opinion on an price for a MAF and Full Throttle thingy? My husband went online, (not sure where), but the MAF was about $700 and the Throttle jigger was about $80. Thanks for any input!
Old Nov 7, 2008 | 09:35 AM
Darover's Avatar
Default RE: Mass Air Flow
D1 or D2 ???
Old Nov 7, 2008 | 09:43 AM
akc's Avatar
akc
Sorry, its a 2000 Discovery II with 165K on it...
Old Nov 7, 2008 | 09:54 AM
So you need a MAF and be more specific on the other part.
A MAF for a 2000 is around $130 plus and easy to replace.
Why does he think he needs these parts, is there a check engine light on, if so what codes did they find?
Old Nov 7, 2008 | 10:05 AM
akc's Avatar
akc
You may remember me from a month or so back. I was the idiot mom who had the check engine light on for a long time, with the mechanic that was also an idiot. After getting it back from 2300 dollars worth of work, it still did the same thing, sluggish, engine light blinking...the first mechanic did all of the stuff you guys said, (plugs, wires, etc.), new fuel pump. He apparently cleaned the MAF, and one of the posters here told me that you never clean the MAF and that the idiot probably ruined it. Needless to say, I found another mechanic who says it is the MAF sensor? Check engine is on and blinking...Does that sound right?
Old Nov 7, 2008 | 10:34 AM
Darover's Avatar
Do you have the codes from the obd2 reader ???
For the part, just go to the dealer or order from a reputated seller like Atlantice British, Rovers North or someone like that. There's way too many people taking advantage of high end vehicle owners on the net.
Old Nov 7, 2008 | 01:14 PM
Disco2Guy's Avatar
Call Tony at Cerrone's. I got a Bosch MAF earlier this year for $160 shipped.
Operated by: Cerrone's European
2306 El Camino Real Redwoood City, CA. 94063
Business Hours: Mon-Fri 8am-5pm PT
(650) 365-4145 Ph. (650) 365-4183 Fax
Toll Free: 1-800-736-7992
Old Nov 7, 2008 | 01:36 PM
Tonyy is a good way to go but first, you really need the codes read, get back to us with them.
Old Nov 12, 2008 | 07:17 PM
akc's Avatar
akc
Just an update: Mass airflow replaced, running good, but my local mechanic is seein a code of: 6th cylinder? What is the firing sequence? Unfortunatley, the check engine light is still on, but he is getting a 6th cylinder code. Thanks so much!
Old Nov 12, 2008 | 10:24 PM
Switzer's Avatar
ORIGINAL: akc
You'll see this a lot in other posts: Change your spark plug wires to Magnecor 8mm (blue) wires. Change the plugs to Champion 7318 plugs or Bosch Platinum +4 (or +2). Only use Magnecor wires. With your high mileage I think it is a safe bet to assume the current wires and plugs are on their last legs.
The firing order starts with the front driver side cylinder. It goes 1-3-5-7 front to back drivers side, 2-4-6-8 front to back passenger side of engine.
Cheers,
Pete
