Mass Air Flow code and O2 Codes Help!
Old Jul 22, 2012 | 09:02 PM
bigcraigman's Avatar
Default Mass Air Flow code and O2 Codes Help!
Have an ultragauge and got p0103 which is value too high and I have a brand new MAF sensor on the disco. Also have too rich codes on Bank A and Bank B. Really confused about the MAF code and what it actually means. I already read the Rave. Can the MAF code cause the o2 sensor codes. It was running too lean now too rich LOL. Qwerky BRIT! Any help greatly appreciated.
Old Jul 22, 2012 | 09:15 PM
Always post the fault code numbers so we have better information.
Your new MAF, is it a Bosch with the exact part number stamped on the barrel like your old one, if not, that is your problem, you can use after market or generic Bosh replacements.
Old Jul 22, 2012 | 09:22 PM
P0172 and p0175 for the 02's. The MAF sensor is Bosch got it from autozone. It has been 2 months and hasn't thrown a code yet.
Old Jul 23, 2012 | 09:45 AM
How mechanical are you? The MAF can cause those codes. I would suggest you read in the Rave regarding testing the MAF with an OHM meter.
If you want to double check the correct MAF number, post your part number located on the barrel of the MAF and I'll cross it with mine.
alpheus
Oct 27, 2010 05:29 PM
Gavster
Apr 15, 2009 01:44 PM
Gavster
Apr 10, 2009 02:49 PM
akc
Nov 13, 2008 08:24 PM
flyinrover
Feb 24, 2006 12:04 PM
