Master Cylinder
I replaced my transfer case rear output shaft bearing. It wasn’t so bad of a job. But now I have a slow seeping leak between the brake fluid reservoir and the master cylinder. Is there any repair for this other than replacing the whole master cylinder assembly?
Are the seals available by themselves? The reservoir from Rovers North is a little over half the cost of the whole master cylinder from Atlantic British.
Get the Aluminum body aftermarket MC On Ebay for 60-150.00 vs the rebuild kit for 50-75.00. You will have to remove the MC anyways to rebuild it you will also need to bleed the brakes either way.
Replacing it is certainly the best solution. I personally prefer the aftermarket units with the aluminum body vs the OEM metal unit. I’ve installed a good amount of them & have yet to have one of them have the reservoir seals leak like the OEM design.
Where do you get them best? I need to do it pretty soon.
