Master Cylinder
Old May 6, 2019 | 06:06 AM
Colorado David's Avatar
Default Master Cylinder
I replaced my transfer case rear output shaft bearing. It wasn’t so bad of a job. But now I have a slow seeping leak between the brake fluid reservoir and the master cylinder. Is there any repair for this other than replacing the whole master cylinder assembly?
Old May 6, 2019 | 06:47 AM
lordmorpheus's Avatar
You can replace just the reservoir. The new reservoir will come with the seals to master cylinder junction.
I got mine from RoversNorth years ago.
Old May 6, 2019 | 06:51 AM
Thank you.
Old May 6, 2019 | 06:57 AM
Are the seals available by themselves? The reservoir from Rovers North is a little over half the cost of the whole master cylinder from Atlantic British.
Old May 6, 2019 | 08:07 AM
Best4x4's Avatar
Get the Aluminum body aftermarket MC On Ebay for 60-150.00 vs the rebuild kit for 50-75.00. You will have to remove the MC anyways to rebuild it you will also need to bleed the brakes either way.
Old May 6, 2019 | 09:28 AM
After some thought, I’ve decided I need the master cylinder so it’s on the way from Atlantic British. Thanks.
Old May 6, 2019 | 09:50 AM
CollieRover's Avatar
Good decision.
Old May 6, 2019 | 10:14 AM
Best4x4's Avatar
Replacing it is certainly the best solution. I personally prefer the aftermarket units with the aluminum body vs the OEM metal unit. I’ve installed a good amount of them & have yet to have one of them have the reservoir seals leak like the OEM design.
Old May 7, 2019 | 04:56 PM
Where do you get them best? I need to do it pretty soon.
Old May 7, 2019 | 05:19 PM
Best4x4's Avatar
Last one I grabbed off of Ebay for 52.00 shipped. Prices will float up & down a bit.
