Master Cylinder Replacement
Old Mar 31, 2010 | 02:47 PM
bantham1's Avatar
Default Master Cylinder Replacement
I am going to be replacing my master cylinder out on my 98 D1. Any tips on keeping the air out of the system and bleeding?
Old Mar 31, 2010 | 03:30 PM
No matter what you do, you will get air in the system. That being said, make sure to bleed the master cylinder before installing the lines, the do a full 3 pint DOT 4 brake flush and you'll be set.
Old Mar 31, 2010 | 08:09 PM
bantham1's Avatar
What is the proper way of bleeding the master cylinder before installing the two lines?
Old Mar 31, 2010 | 09:38 PM
okdiscoguy's Avatar
put it in a vise on a bench while level. Install 2 hoses with fittings into the ports and fill the reservoir. Put the ends of the hoses in the reservoir. Pump the cylinder with a screw driver until no air bubbles come out of the hoses. Install.
This can also be done while mounted in the truck if you goof on something, but be careful about spilling the fluid on anything. Brake fluid will eat paint.
Old Mar 31, 2010 | 09:46 PM
greg409's Avatar
Mike's correct on the (3) pints, I actually used (2) quarts to get a decent flush.
luck,greg
Old Mar 31, 2010 | 10:16 PM
bantham1's Avatar
My old MC was leaking fluid and I did notice it eating the paint. I will have to spray it off with some simple green once I am finished. At least my disco has aluminum body and it leaked in the engine compartment only. I also could not find a fitting to screw into the MC threads so I may just plug it with my fingers while i have a helper pump the brakes. Maybe harbor freight will have an adapter to fit.
Old Mar 31, 2010 | 10:50 PM
Danny Lee 97 Disco's Avatar
You might find some plastic plugs somewhere that will fit.
Old Apr 1, 2010 | 08:26 AM
luck,greg
When bleeding the brakes, you have to continue to keep rebleeding each wheel till you get clear fluid coming out so 3 is a safer amount.
Old Apr 1, 2010 | 09:48 AM
okdiscoguy's Avatar
To the OP, most parts houses have bleeder kits for the MC. They come with a ton of plastic fittings and the hoses. You could also just run it by your local brake shop and have them bleed it for you and then run home and install it.
Old Apr 1, 2010 | 10:47 AM
antichrist's Avatar
These work great.
LRadventure
Aug 27, 2014 03:21 PM
kingnebby
Apr 10, 2011 04:56 AM
kdarling
Jun 5, 2007 07:19 AM
TVO
Mar 15, 2007 12:08 PM
leebuhrul
Feb 26, 2006 03:38 AM
