master cylinder and sensors about ta poo!
Old May 14, 2011 | 10:43 AM
culture1's Avatar
7th Gear
Default master cylinder and sensors about ta poo!
so i put on new break pads and rotors all the way around . bled the breaks and their still dragging. Whats the rotation to bleed the breaks? also replaced crankshaft sensor recently and shop said my codes are reading for a bad master cylinder. I would like to drain all the fluid from the break system and see if that helps. any advice? things to look out for? thanks, Erik
p.s. this forum rocks! have received so much help from everyone. thanks!
Old May 14, 2011 | 11:03 AM
thospb's Avatar
A brake system flush cannot hurt. The conventional pattern to bleed brakes is to start with the wheel farthest from the Master Cylinder and work your way closer to the Master Cylinder. Some people will pay extra for colored brake fluid so they can see when the fresh fluid is coming out but it is not necessary. Also, just use DOT4. Never use synthetic as it will create a collection point for moisture.
truknoom
Jan 11, 2013 12:41 PM
CresFresh
Oct 18, 2008 12:52 PM
kdarling
Jun 5, 2007 07:19 AM
TVO
Mar 15, 2007 12:08 PM
leebuhrul
Feb 26, 2006 03:38 AM
