Mercon V synthetic ATF?
I just noticed Mike's recommendation to someoneabout picking up Mercon 4 for a tranny fluid change.
I've alreadybought up the local Advance's stock of Mobile 1 Mercon 5 synthetic.
I'm not fully versed in the nuances of the differences between the two.
Can anyone advise if this stuff is ok to use?
Danka.
Danka.
RE: Mercon V synthetic ATF?
I used penzoil Multi ATF.
PENNZOIL® MULTI-VEHICLE ATF is suitable for use in applications requiring:
[ul][*]DEXRON®, DEXRON®-II, DEXRON®-III.[*]MERCON®, MERCON® V.[*]Chrysler/Dodge/Jeep/Plymouth (except NAG1 that requires Shell 3403 ATF).[*]Allison C-4.[*]Toyota T, T-III, T-IV.[*]Honda Premium Formula ATF, ATF-Z1 (except in CVTs).[*]Mitsubishi/Kia/Hyundai SP, SP-II, SP-III.[*]Nissan Matic -D, Nissan Matic-J.[*]BMW LA2634, LT71141. [/ul]
The what's weird about all the Dextron (Dexron?) trany fluids: most say compatible with Dex II DexIIE DexIII etc. I've yet to see Dex IID which the 94-96(at least) D1 manual calls for. Why list Dex II and DexIIE but not DexIID if it IS compatible? I've been using D/M fluid which is supposed to work with DexII.
