Method for pressing radius arm bushings?
Old 04-23-2024, 12:20 PM
Brandon318's Avatar
Originally Posted by WaltNYC
Has anyone every tried "double hose clamping" a bushing (to prevent mushrooming as described above)? One closer to the leading end and another closer to the trailing end?
You could loosen the first as the bushing enters the arm and the second as you get the bushing closer to completely installed.
One at the bottom isn't really needed since the moment you press even just a small bit in, the hole you're pressing into acts like a clamp.
And TBH, clamping the top is an overkill but one of those things where it's like... so easy, might as well do it? If the shell is going to break, it's going to break with or without a clamp. That one above that shattered had a clamp on the top up until the very last millimeter I could keep it on.
WaltNYC (04-23-2024)
Sandman614
01-23-2022 09:23 AM
Alex_M
06-17-2018 03:36 AM
Shiftonthefly1
04-07-2015 06:49 AM
ebg18t
04-27-2012 12:37 PM
Disco Mike
05-04-2011 07:08 PM
Quick Reply: Method for pressing radius arm bushings?
