Castor correction arm vs bushings
Old Apr 26, 2012 | 06:21 AM
ebg18t's Avatar
Default Castor correction arm vs bushings
I am looking at correction the front castor. What are the opinions of correction arms vs correction bushings?
Castor 3 degree correction buhings
Old Apr 26, 2012 | 08:14 AM
I believe you will find those are for D1's, I don't believe anyone makes them for a D2.
Old Apr 26, 2012 | 08:47 AM
RoverMasterTech's Avatar
Wow... never seen those, so you put one behind the axle facing down and one in front facing up? You can always drop the trailing arm where it meets the frame but that takes some fabrication.
Old Apr 26, 2012 | 09:00 AM
Don't you agree, these are for D1's only?
Old Apr 26, 2012 | 09:09 AM
drowssap's Avatar
they are listed on the web site as "Discovery 2 Bushes"
Old Apr 26, 2012 | 06:38 PM
ebg18t's Avatar
They are listed under the d2 section. I sent an email to devon4x4 for clarity.
Are there a reasonably priced set of front castor correction arms?
Old Apr 27, 2012 | 05:59 AM
ebg18t's Avatar
I received the email back from Devon4x4 that the are for the D2 which is great news. But the cheapest shipping is 77GBP.
Old Apr 27, 2012 | 07:27 AM
I stand corrected, used to be you couldn't get them.
How much of a correction are you needing?
Old Apr 27, 2012 | 12:37 PM
Those are cool as hell, BUT. Your going to have to eyeball correctness, unless you feel like pressing them in, doing a caster sweep, then pressing out and pressing back in for an adjustment. With a 3" lift like you have, I would go straight for all the way up in back and all the way down in front
cybercop
Jan 30, 2015 06:32 AM
kman35ca
May 27, 2012 06:57 PM
Disco Mike
May 4, 2011 07:08 PM
batiscan
May 24, 2010 09:04 PM
kjj0506
Sep 22, 2007 06:34 PM
