MethodWheel on KO2's - 255/70-16.
Old Oct 15, 2019 | 12:26 PM
  #21
SundayFunday's Avatar
+1 Agree with above.
If you look at load specs for each spring weight, it should be relatively easy to add up the weight you travel w vs stock & see what makes most sense.
And again, those wheels are so awesome
Old Oct 15, 2019 | 02:23 PM
  #22
parareid82's Avatar
Great info here. I just got a 99 D2 and it is all stock. I am thinking of going with the TF Med 2 in lift with the KO tires. Anyone know what size tires I should be looking at with the 16 in stock rim with the 2 in lift?
Old Oct 15, 2019 | 02:32 PM
  #23
whowa004's Avatar
265/75/16 should fit nicely, might have some rubbing at full lock on the radius arms but I didn't find myself at full lock very often so it wasn't a concern. They look damn good too. Helps that the K02s run a little smaller than their advertised diameter
Old Oct 16, 2019 | 07:37 AM
  #24
parareid82's Avatar
Default Tirea
Can I get away with the 265’s without the 2 in lift until I get around to doing the lift??
Old Oct 16, 2019 | 08:50 AM
  #25
whowa004's Avatar
That I can't speak to but I would imagine some rubbing would take place, not sure to the extent of it though. I bought mine with a 2" lift and the 265s on it.
Old Oct 16, 2019 | 12:22 PM
  #26
GoRoll's Avatar
with the stock wheels? Probably only with lots of weight. My 255/70 rubs but butnothing crazy I also got a wider wheel.
Old Oct 16, 2019 | 12:29 PM
  #27
parareid82's Avatar
Default Wheels
Sorry I wasn’t as clear as I should be. I am going to do the 2in lift but not right now. I need to get tires ASAP so I wanted to get the biggest tires in prep for the lift. Hope that makes sense. If it rubs a tiny bit I’m ok with it. I’ll do the lift in a few months. Thanks to all
Old Oct 16, 2019 | 07:39 PM
  #28
GoRoll's Avatar
Ahhh but base on my 255/70-16 it rubs. Only when entering driveways / off camber...
But my rims are 1 inch wider than stock. My guess would be that 265 will rub but nothing crazy. You can always hammer the inside fenders.
Old Oct 17, 2019 | 11:30 AM
  #29
parareid82's Avatar
Default Lift
Well I just bought the lift today TF HD 2in. Guess I don’t have to worry now lol. Just need to decide on the BFs or Goodyear’s.
Old Oct 17, 2019 | 02:35 PM
  #30
GoRoll's Avatar
Let us know how it rides!
