In the Middle of 2003 CDL Install. How do I get these gears out of the T/C?
Old Dec 14, 2011 | 08:23 PM
bosshogt's Avatar
Default In the Middle of 2003 CDL Install. How do I get these gears out of the T/C?
Hello All,
I'm following Joshes 03 front output swap to a T and all has been going well so far. I got the front output housing off now after about 12 hours of dissasembly. I cannot get these gears to come out!
  • Should I turn the rear wheels a little to remove binding in the gears? (I only have one jack) I'll have to get a 2x4 to hold up the T/C case
  • The writeup shows putting a screw driver in the second row hole. I cant reach that because it is to far inside the case to reach from the side.
  • What if I take it out of park and put it in neutral.
Any help would be appreciated.
On my doner T/C case the gears came out with a little wiggling.
Old Dec 14, 2011 | 10:19 PM
bosshogt's Avatar
So I went out and put it in neutral, put the rear wheels on jack stands. I'm able to turn the gears freely, but the gear will not come forward. Any ideas, I guess everyone that has already done this went to bed.
Old Dec 15, 2011 | 09:05 AM
Sure, send Josh a message and ask him to call you.
Old Dec 15, 2011 | 11:42 AM
bosshogt's Avatar
Ok did that. Come on Disco Mike you are supposed to know everything
I went out and put the rear wheels on jack stands. I'm able to spin the gears freely with the tras in neutral. Now I'm going to put the Hi/low selector back on for the second time and see if I can change the T/C case to neutral. I've done alot of Internet research no one talks about these being stuck. Great.
Old Dec 15, 2011 | 01:26 PM
hilltoppersx's Avatar
can u bend the end of a screwdriver to get it in there? i use a bent one to change my plug wires. wrapped in tape of course but makes life easier.
Old Dec 16, 2011 | 10:33 AM
bosshogt's Avatar
I have a tool like that its a hooked end puller from Harbor Freight. But the clearance from the gear coming out of the case is not the problem. If I lift up the gear it will clear. The gear set will not come forward after twisting. I dont get it. I must have to move the dog clutch selector into neutral. If I dont figure it out soon. Im going to drop the case and swap it for the other other one. Its just so heavy its going to defeat the purpuse of going this route. Plus I have to take apart rear drum brake and prop shaft. Its another 2 hours of crap.
Old Dec 16, 2011 | 02:59 PM
so it will twist? just not come forward? hmmm... i dunno man.. i stared at the rave and its the same exact thing check out page 574. they talk about using a tool to stick in where josh says use a screwdriver, is there some kind of lock mechanism in there?
Old Dec 16, 2011 | 08:11 PM
threalassmikeg's Avatar
Did you remove the hi low selector shaft detent screw spring and ball??
see pg 9 of josh's insrtuctions. If you haven't done it yet, do it now
Old Dec 16, 2011 | 11:05 PM
bosshogt's Avatar
Ok, I'll remove the detent ball, screw and spring. But it looked like that order was after the gears had already been removed. I'll also try the 1/4" extension in that side hole.
Although in the RAVE picture it looks like the second row is supposed to be used. I cannot reach that because the gears are not that far forward.
Thanks,
Dave
Old Dec 17, 2011 | 01:08 AM
bosshogt's Avatar
Ok I removed the ball and spring. The Hi/Low selector moves easily now. I put the trans in neutral and I can slide the hi/lo selector to neutral hi and low. I can spin the gears but no deal coming forward. I am out of ideas now. I have spun it backwards and forwards. Only other option I have its to remove the large inspection plate and see if I can nudge the gears forward with a broom stick or screw driver handle.
I have the other front locking output ready to install in front of me. Looks like both sets of gears are cut slanted towards the same direction. With pulling seems like they should slip forward. I just dont get it.
