Middle-row dome light
Old Jan 23, 2022 | 08:35 PM
Hoosier72's Avatar
3rd Gear
Default Middle-row dome light
Middle-row dome light won't turn off.
2004 Land Rover Disco
Old Jan 24, 2022 | 06:45 AM
adalton's Avatar
Check to make sure all doors are closed and the button is not pressed. Mine wouldn't turn off for the whole day until I realized my trunk was slightly open.
Old Jan 24, 2022 | 09:30 AM
mollusc's Avatar
Should be on the same circuit as the other dome lights. So either the switch is in the wrong position, or the switch is messed up internally.
Old Jan 24, 2022 | 12:18 PM
Hoosier72's Avatar
3rd Gear
What "button" would that be? (All the doors are securely closed.)
Old Jan 24, 2022 | 12:20 PM
Hoosier72's Avatar
3rd Gear
What would the correct switch position be?
Old Jan 24, 2022 | 12:31 PM
adalton's Avatar
Should be right next to the light if Im thinking about the correct light. Should be slightly farther out than when the button is pressed.
Old Jan 24, 2022 | 01:00 PM
mollusc's Avatar
Why not try using the switch on the light to work it out yourself? It's literally on or off.
ajnolin
Jan 17, 2020 09:10 PM
philh5197
Jul 17, 2011 02:32 PM
Aj6543
Apr 29, 2011 10:36 AM
Roveroh
Jul 28, 2008 01:34 PM
sharonsbaby
Sep 26, 2007 09:10 PM
