Mild engine vibration
I had what looked like a broke or about to brake drivers side motor mount, I ordered a set from Lucky8, they were Britpart I believe. My drivers side turned out to be completely sheared. I replaced both motor mounts about 30k miles ago already, didn't last too long, not sure what brand I put in the first time. Anyway, immediately when I started the engine I could feel a vibration in the steering wheel, and when I put it in gear the car would have a mild vibration throughout the body that seem to come and go?? It's almost like it's worse when the engine is cold? I scoured over everything under the hood, couldn't find anything bent or touching the frame due to me jacking the engine up, I checked/jacked up the rear tranny mounts and they look great also. What I don't know is if the engine had this slight vibration for a while before, and I didn't feel it due to the bad motor mount? idk. Looking up at the damper when the engine is idling, I can see a slight wobble, the bolt is tight. any ideas?
I put a bottle jack under the transfer case, jacked it up and the mounts looked solid. I even removed the lower nut on the rear mounts so I could get a better look at them due to them having the shielding covering the rubber. They looked and felt fine..
I do have a slight "gravel" sound at idle that I've had for a few years, it's never really pronounced "here I am" yet. I've used a stethoscope to try and isolate where this mild sound is coming from, and it seems like it's around the front of the tranny? I thought it was possibly my flex plate, and about a year ago, I removed the inspection/torque convertor plugs and I couldn't see anything out of the normal, I have also read that you really cant see a bad/cracked flex plate through those holes. And it seems everything I've read about the sound a bad flex plate makes doesn't match what I am hearing with my rig. The reason I am bringing up the strange sound I have heard off and on over the last few years is...I'm now noting a slight vibration when the starter is turning the motor over, but not always, usually only on cold start. So I'm wondering if my flex plate is the culprit. When I have some dry weather I'm going to get back at it. Im going to read up more on flex plate issues on here.
The Deputy (04-09-2019)
I kind of have the same thing, always thought it was normal more or less, or possibly due to the Kent 180 camshaft, or because I don't have any carpet or any interior trim. At idle, regardless of gear position, I'll feel a slight vibration that lasts for ~2 seconds, goes away, then comes back at random intervals of like 3-10 seconds. New motor mounts all around, new flex plate, 8k miles on my full engine rebuild. Fwiw, I installed a brand new genuine crank pulley and it still has a very slight wobble.. so I think that's normal.
Thing is I don't really have anything to compare to as I pretty much tore down the rover as soon as I bought it. And I've never driven another rover
bonnettoboot
03-06-2007 05:08 PM
