misfire
Old Apr 25, 2015 | 09:03 AM
Celto 4's Avatar
Default misfire
Gooday all finally getting around to address the disco problem getting misfire 1 and 3 cylanders and a 1300 code has new coils and 8mm wires and plugs pulled the plug getting good spark and it was wet with gas i have new upstream o2 sensors however prior to this happpening i had a rattling cat going to get a compression tester and do a test any use in doing a cooling system pressure check?thanks
Old Apr 25, 2015 | 09:19 AM
Celto 4's Avatar
oops truck has 156,00 fault free so far
Old Apr 25, 2015 | 03:17 PM
drowssap's Avatar
If you have access to them, they are both good test to be done at that milage anyway
Old Apr 25, 2015 | 04:59 PM
Celto 4's Avatar
Smile
Hi everyone well after chasing round all afternoon i was unable to rent or purchase a coolant pressure tester with an adapter that fit i `will do a compression test tomorrow,,,,,just to see where things are,,,,,,thing is with this millage should i maybe just go ahead and tear it down?the truck is off the road and garaged,,,been a good truck this far quick question should i still go ahead and warm it up with the obvious misfiring or do cold thanks
Old Apr 26, 2015 | 04:24 PM
Celto 4's Avatar
hi all got a compression tester is pulling the 30 amp fuse for the fuel pump enough or do i need to locate and pull the relay as well thanks
Old Apr 26, 2015 | 06:25 PM
Celto 4's Avatar
did the test cold as i had the plugs out for inspection will do again after warm up very consistent just under 150 passenger side bank all the same and 130-135 drivers side
Old Apr 27, 2015 | 08:19 AM
drowssap's Avatar
I think I read that the pressure test that advanced uses fit LR, not sure I have one from HF.
but it would be interesting to see what your final numbers, are already you have 10% difference from right to left.
Old Apr 27, 2015 | 08:52 AM
Celto 4's Avatar
Thank you for your reply i am going to redo the test warm and will post after should i get the necessary fittings to do a coolant system check?want to rule out slipped liner as much as possible before teardown no smoke in exhaust...... or will the condition of the head gasket show a slipped liner?
Old Apr 27, 2015 | 09:00 AM
drowssap's Avatar
I would also pressure test the cooling system so you don't have any surprises.
on you compression test if you put a table spoon on oil in the cylinder and the pressure goes up substancally then you most likely need rings
Old Apr 27, 2015 | 09:09 AM
Celto 4's Avatar
Thank you will proceed with that and let you know have a good day
