misfire again!?
Old Jan 6, 2009 | 12:57 AM
ivan's Avatar
Default misfire again!?
ok so my disco is a 2002 69k 4.0 westminster edition a/t vin: salty i've owned it for about 4 months but shortly after i bought it started running rough n threw a check engine light had plugs n wires replaced plugs were ngk laser series platinum ($16.00 each) wires were sti 8mm (about $150.00) it ran fine for about two months then one morning i start it up n it ran very bad for about 30 seconds then it calms down n runs fine most the time but after that it always starts missing really bad outta no where here n there regardless if its cold or been drivin for hours the check engine light is on most the time also codes r cyl.8 misfire cyl.5 misfire i took it to 2 shops columbia rovers and greenoval motors in portland or. the shop replaced coils, crank position sensor, tested fuel pump, injectors and did a fuel system cleaning. still no luck both mechanics had no more ideas im so frustraded! im about to blow this thing up i love my truck but im getting tired of throwing so much money at it. anyone have any ideas? please help
Old Jan 6, 2009 | 01:04 AM
sloppyjoe's Avatar
Default RE: wtf!? misfire again!?
i hope you have learned the golden rule of dealing with most shops.
the majority are parts swappers and not problem solvers. you can band aid a problem with new parts, but unless the real issue is fixed it will keep reoccurring.
ask here first, then go to the shop.
my mind instantly goes to the TPS, but that is me.
lets wait on discomike. he is the dude
Old Jan 6, 2009 | 01:19 AM
AK Rover's Avatar
I'm putting my money on the wires being bad.
Old Jan 6, 2009 | 07:04 AM
jkid's Avatar
STI wires are junk. I say get them out of there and replace them with some magnecores or stock replacement wires.
Old Jan 6, 2009 | 11:30 AM
sloppyjoe's Avatar
ahhh i missed him saying STI wires. those are crappola.
Old Jan 6, 2009 | 11:48 AM
hazletbassist89's Avatar
Gotta go with wires. Get yourself some Magnecore 8mm wires and Bosch Platinum +4 plugs. You won't be disappointed by them.
Old Jan 6, 2009 | 03:33 PM
ivan's Avatar
Default RE: misfire again!?
ok thanks guysill try the wires n plugs again hope that takes care of the issue. ill keep everyone posted
garover
Feb 13, 2019 07:18 PM
abran
Jun 30, 2014 12:43 PM
Gromeo
Jan 24, 2013 03:41 PM
davidlafrance
Jun 13, 2012 07:44 AM
herblatham
Jan 25, 2010 06:25 AM
