Misfire Code P0307
Old Feb 14, 2018 | 02:06 AM
Safari01's Avatar
Exclamation Misfire Code P0307
Morning Rover Owners,
I recently got a flashing check engine light and ran the scanner and came back with P0307 , fuel injector . first thing I did was replaced the spark plug and is still getting the flashing light and shaking
O2 sensors will be replaced this weekend and is wondering if its actually the fuel injector itself or the O2 sensors that is making my truck shake at the light and feels like its driving rough a bit
Has anyone gotten this issue with their rig?
2001 Disco 2 60k
Thank You
Old Feb 14, 2018 | 04:56 AM
mln01's Avatar
That code is for a misfire on cylinder 7. How old are the spark plug wires and what brand are they? Try watching for arcing after dark with the engine idling. With a P0307 only I'd focus on the #7 wire next.
Old Feb 14, 2018 | 10:41 AM
samroy92's Avatar
It could be a bad wire from the coil pack side to cyl 7. Does it make any faint ticking noise? Sometimes that can be a spark arcing to the firewall or back of engine. You can buy a spark testing tool that you hook up the wire (
Amazon Amazon
). Maybe want to consider getting all new plugs and wires. Forewarning, its not easy to access the coil pack and takes a couple hours.
Old Feb 14, 2018 | 10:58 AM
Best4x4's Avatar
Or it can also be a dead #7 position on the coil pack. It does happen (had it myself on my 02 Kalahari), it might even still show a spark with a tester, but that doesn’t mean it’s a hot enough/strong enough spark for proper combustion. If you’re going to go to all the trouble of removing a spark plug wire I’d honestly just get new coil packs & wires, and then be trouble free for a very long time.
Old Feb 14, 2018 | 03:15 PM
The Deputy's Avatar
This one...no...a thousand others...yes...lol.
But seriously, you've got quite a bit of good info already. How they get you fixed up fast.
Brian.
Old Feb 15, 2018 | 12:27 AM
Safari01's Avatar
Default Misfire
Thanks for all the help guys will be stalling coil pack and wires this weekend, will keep you guys updated
Cheers!
bhowell450@gmail.com
May 3, 2017 04:33 PM
rtindle1975
Jun 11, 2014 03:05 PM
hatt53
Mar 27, 2013 05:16 PM
Murph2121
Feb 20, 2013 01:00 PM
mtat
Oct 2, 2008 10:03 PM
