Misfire Mystery
Old Jul 18, 2017 | 10:39 AM
akbrewer's Avatar
4wd High
Default Misfire Mystery
I have a 2004 Disco II with 120k miles, and it is encountering misfires. The plugs and wires have been replaced, the O2 sensors and catalytic converter were recently replaced. The head gasket and items relating to cooling have been replaced within the last 20k miles. The misfire happens after about 30 minutes of driving and is primarily on cylinder 4, every now and then cylinder 6. My mechanic has done extensive compression, leak, and cylinder testing, and is stumped. The truck does not overheat, when all of this is occurring the temp stays at 194. The mechanic does not want to just throw parts at it, so we are looking for ideas. Thank you in advance for your help.
Old Jul 18, 2017 | 10:49 AM
LR03NJ's Avatar
How about the coil packs? Tune up wont be complete without replacing coil packs in some cases. I guess your mechanic just dont want to dig in there. Cheers
Old Jul 18, 2017 | 10:51 AM
Red5's Avatar
Did he check the injectors?
Old Jul 18, 2017 | 11:10 AM
Friday Night Disco's Avatar
clean the gas cap and filler spout with some 3m scotch brite
Old Jul 18, 2017 | 11:16 AM
No Doubt's Avatar
Swap the locations of your misfiring fuel injector with a non-misfiring fuel injector to see if your misfire location/code moves.
Swap the locations of your coil packs to see if the misfire location/code moves.
Check your fuel pressure if the above doesn't identify a problem. Low fuel pressure might be a fuel check valve, fuel pressure regulator, or fuel pump problem (or clogged fuel rails).
You can do all of the above diagnostics without buying any new parts.
I'm a big fan of free diagnostics locating the precise problem before throwing parts at the issue...though I get that there are moments where it makes sense to simply try a cheap part.
Old Jul 18, 2017 | 02:00 PM
zuke's Avatar
Default Might try this
Blow the cobs out of it. Take it out on a lonely stretch of road and give it hell for about 10 miles. I had a persistant no. 7 misfire. I tried everything. Then one day i was pi**ed and took it out. It worked.
Old Jul 18, 2017 | 02:06 PM
Dave03S's Avatar
Add a can of Seafoam to half a tank of top tier premium gas and do the above ^^^
Old Jul 18, 2017 | 03:07 PM
dtmbinb's Avatar
Exactly. I run a can of seafoam in a half tank of gas in every one of our vehicles every 3000-5000 miles. Works great.
Old Jul 18, 2017 | 10:16 PM
shady milkman's Avatar
I had a misfire on cylinder 4 yesterday. Pulled off the boot and out came the wire and insulator. Wires have 5k miles on them and are STI wires.... bought a set of magnecors today
Old Jul 18, 2017 | 11:18 PM
OffroadFrance's Avatar
Happy days are here to stay ............... coil packs are 'wicked' for most mechs eh.
