Misfire and no codes?
You put new plugs and wires on. If the coils aren't completely up to snuff, they may not like the new parts if they have a slightly different resistance. Just because it was working okay before doesn't mean that it will continue to work after you replace a bunch of parts.
Sixpack, a tip for the future.
Never replace too many parts all at once before testing as it is difficult to figure out what has made the engine change, yep I know, easier said than done. Always test as you go along where possible as it might also be defective parts albeit they are new.
I agree
But, not able to be done this time.
Previous owner had new plugs and wires he hadn't installed. I bought the mechanical parts to be sure and fix the tick the engine had. They all seemed to be common wear-out and suspect parts anyway. The oil pump's outer gear was cracked, so problem solved. At least that one.
I'm going to check for a vacuum leak next.
Strange problem, hopefully something simple.
Frustrating, none the less.
Sounds possible, but unlikely to me. Unless it can be common for a Disco??
I need to check some things, but trying to gather as many ideas as possible.
New coils and upper intake gasket are under $60, so not terrible to do if that doesn't fix it. But waiting on parts, and guessing it may be the problem, not so much.
I'm wondering if the temp light on and needle not moving could point to the mass air sensor being bad?
I just unplugged it and put the intake tube in the back of the Disco until I was finished.
I didn't clean the MAF either.
So nothing with it should have changed.
Hopefully that works for you. Are you getting any codes now? As I read in the beginning there was no code but you were able to detect misfire. Could it be pending? A misfire could be pending but disappears once it completed a drive cycle. As it was mentioned a complete tuneup might do the job and that includes the coil packs. Good luck again.
Nah, no pending codes either.
Have "cleared" everything with the Hawkeye regardless, disconnected battery and let it sit a few minutes a couple times also.
It runs rough on start up, have to pedal it to keep it running, idles 5-10 seconds and dies. It seemed like it wanted to clear up and run right, then it stumbles again.
I'm sure a coil, or one of several engine sensors could be the cause, or a vacuum leak. I just can't belive there isn't at least an O2 code from rich exhaust.
The Hawkeye and the Disco ecu seem to be communicting correctly too. As I can test circuits, operate windows, I turned the alarm off, turned key chime off and back on, ect.
Coil packs should be here by Thursday, and hopefully on Friday night, Saturday afternoon.
I hate gremlins.
I only hope I can find a definate problem. That way, when the next guy wonders why there is a misfire, and no codes; hopefully I have a good answer to save them the headache.
I hate gremlins.
Sorry im on phone cant view previous. But did you give your MAF a good cleaning? Saturate it with crc maf cleaner until it drips and let it dry completely. Btw, try not to remove battery or reset for the mean time. Let the ses blink if its bad and wait until code shows up. Also remove air filter after you clean maf and try to start again after its completely dry from cleaning.
