Misfires
hi; any info I'll appreciated
1999 Disc I 150,000 miles I'm wasting gas, when I give it gas feel like it needs a tune and sometimes makes a sound like air explosion only when a push the pedal all the way down, just change spark(bosch,cables standard, fuel filter standard, and I don't want to buy the coils if I don't need to.
this car was seating on a driveway about 4 months because of fuel pump problems and alternator, I fixed them both is running but need help
thanks
thanks
I took sparks #1 and #2 to compare them and they look exactly the same, so I went to and auto store they gave me the same codes, but they reset the computer again, but this time I actually felt a difference a smoother ride,
I don't know ifthe (check engine light) will light up again,but for now feels a little better
when the CEL is on, your system defaults to a rich mixture. You get poor mileage and performance. I would still look into Magnacor wires and Bosch plugs, I just put OEM bosch on, and I can tell she is going to beed new ones soon....
ok, thanks Mike. I just know that I was sooting up the pipe horribly whith misfire codes. I had a plug wire loose. Also sooted it up with a 1496 &1497..... my filler neck had sagged, first causing a broken gas cap and then wearing through the gasket on the second. I had heard about it defaulting to rich and made sense to me, with what I saw...
I have been code free for over a month now....=)
You can have some misfires that can soot up the tail pipe but your ECU won't go full rich on it, actually the 02 sensors will try to lean out your engine to correct the unburned fuel from the bad cylinders.
Mike
Mike
