Misfires
Old Jul 17, 2007 | 02:08 AM
japt29's Avatar
4th Gear
Default Misfires
hi; any info I'll appreciated
1999 Disc I 150,000 miles I'm wasting gas, when I give it gas feel like it needs a tune and sometimes makes a sound like air explosion only when a push the pedal all the way down, just change spark(bosch,cables standard, fuel filter standard, and I don't want to buy the coils if I don't need to.
this car was seating on a driveway about 4 months because of fuel pump problems and alternator, I fixed them both is running but need help
thanks
Old Jul 17, 2007 | 07:23 AM
Default RE: Misfires
Do you have any fault codes?
Send me your tele number and a good time for me to call you and we can talk about it.
Mike
Old Jul 17, 2007 | 10:15 AM
japt29's Avatar
4th Gear
Sorry I Forgot to mention I have codes 301 cyl#1 308cyl # 8 and 1316 two cyl miss cause poor emission, a friend w/ a scanner wrote me this
Old Jul 17, 2007 | 10:45 AM
We need to talk.
Mike
Old Jul 17, 2007 | 05:18 PM
wease206's Avatar
go to a auto store and use there code reader its free
Old Jul 18, 2007 | 09:30 AM
japt29's Avatar
4th Gear
I took sparks #1 and #2 to compare them and they look exactly the same, so I went to and auto store they gave me the same codes, but they reset the computer again, but this time I actually felt a difference a smoother ride,
I don't know ifthe (check engine light) will light up again,but for now feels a little better
Old Jul 18, 2007 | 11:19 AM
okdiscoguy's Avatar
when the CEL is on, your system defaults to a rich mixture. You get poor mileage and performance. I would still look into Magnacor wires and Bosch plugs, I just put OEM bosch on, and I can tell she is going to beed new ones soon....
Old Jul 18, 2007 | 12:11 PM
I don't believe the engine goes to open lupe and full rich when a check engine light is on, there are only certain codes that can cause this and the are rare.
Mike
Old Jul 18, 2007 | 12:15 PM
okdiscoguy's Avatar
ok, thanks Mike. I just know that I was sooting up the pipe horribly whith misfire codes. I had a plug wire loose. Also sooted it up with a 1496 &1497..... my filler neck had sagged, first causing a broken gas cap and then wearing through the gasket on the second. I had heard about it defaulting to rich and made sense to me, with what I saw...
I have been code free for over a month now....=)
Old Jul 18, 2007 | 02:50 PM
You can have some misfires that can soot up the tail pipe but your ECU won't go full rich on it, actually the 02 sensors will try to lean out your engine to correct the unburned fuel from the bad cylinders.
Mike
