misfires after coil, plugs and wire replacment
Ok, I was getting a random misfire code on my 03 Disco. I replaced the coils, plugs and wires. NOW i'm getting mis fire codes on cyl 1, 4, 6, 7 (which happen to be the coil on the drivers side) The car is running as if it was a 4cyl. Any thoughs on this? I"m stumped
2003 Discovery
OK, so I am still having the same problem. The car seems even feels like a 4cyl. I swapped out the coil with the old one thinking that could be the issue...double checked the routing of the wires and checked to be sure they were all seated correctly. I"m STUCK. why am I getting a misfire on only the ones plugged into the coil on the drivers side? Like I said, I tried the old coil.
NOW, I do have a crack in the pipe for the SAI pump on the bend to the exhaust manifold. The rear half on the passengers side. COuld this have anything to do with the problem as this is a pressurized system?
I"m stumped and frustrated. errrrrrr.
THanks,
Steve
THanks,
Steve
