misfires after coil, plugs and wire replacment
Old Mar 31, 2010 | 03:03 PM
jrm123180's Avatar
Default misfires after coil, plugs and wire replacment
Ok, I was getting a random misfire code on my 03 Disco. I replaced the coils, plugs and wires. NOW i'm getting mis fire codes on cyl 1, 4, 6, 7 (which happen to be the coil on the drivers side) The car is running as if it was a 4cyl. Any thoughs on this? I"m stumped
Old Mar 31, 2010 | 03:25 PM
Hows plugs and wires?
I would check your coil connections first, if they are good, I would call the coil supplier and get them to replace it for you under warranty.
Old Mar 31, 2010 | 03:37 PM
jrm123180's Avatar
plugs are new, replaced with bosch +4 and a set of magna core wires. connections seem ok, but I'm going to reset everything and see if there are any changes.
Thanks.
Old Mar 31, 2010 | 03:39 PM
Let us know how it turns out and don't let anyone talk you into changing out the plugs cause that won't fix this.
Old Mar 31, 2010 | 06:06 PM
okdiscoguy's Avatar
You sure you plugged the new coil pack in solid? Got your plug wires routed correctly?
Old Apr 2, 2010 | 06:59 PM
jrm123180's Avatar
2003 Discovery
OK, so I am still having the same problem. The car seems even feels like a 4cyl. I swapped out the coil with the old one thinking that could be the issue...double checked the routing of the wires and checked to be sure they were all seated correctly. I"m STUCK. why am I getting a misfire on only the ones plugged into the coil on the drivers side? Like I said, I tried the old coil.
NOW, I do have a crack in the pipe for the SAI pump on the bend to the exhaust manifold. The rear half on the passengers side. COuld this have anything to do with the problem as this is a pressurized system?
I"m stumped and frustrated. errrrrrr.
THanks,
Steve
Old Apr 2, 2010 | 08:05 PM
What fault codes do you have?
I would do a compression test to see if you have a valve/valve guide hanging up or burned valve.
Old Apr 2, 2010 | 08:51 PM
jrm123180's Avatar
The codes I'm getting are...
0161
0141
0135
0155
1590
0134
1300
0301
0304
0306
0307
0300
I realize that some of the codes are O2 sensors and one is my amigo's light.
the others are misfires....
Old Apr 2, 2010 | 09:41 PM
Willie00d2's Avatar
Do you have 7mm or 8mm Magnacores. I read that you can have problems with Bosch+4's and 7MM wires together.
Willie
Old Apr 2, 2010 | 09:52 PM
jrm123180's Avatar
honestly, I don't know if they are 7 or 8....I could not find it written on the box or the wires anywhere....
