Mismatch of front 02 sensors when replaced.
Hi all.
I just replace my front 02 sensors and the left and right were different looking when I pulled them off.
Both of the replacements looked like the left. I googled some images and it looks like the right one might have been a Bosch?
I just wanted to double check that both of the front 02 sensors should / can be the same and is part MHK100920
Thanks.
Left and right, in correct position as they were on the car.
Left (passenger side) old sensor. Both new sensors looked like this.
Right old sensor, this one looked different from both of the new sensors and the left old sensor.
Thanks.
The physical appearance of the sensor is irrelevant. Different brands are physically different.
Here, for example, is the upstream Walker O2 sensor for the DII.And here is the upstream Bosch brand sensor. Either is fine. Looks to me like your truck maybe had one Walker sensor and one Bosch sensor. Not a problem.
Jason_B (08-02-2020)
Jason, exhaust leaks aren't usually a cause of rough idle. Have you looked for vacuum leaks, or fouled plugs, or clogged injectors yet? Given the age of our Discos, any of these are plausible.
Before I changed the head gaskets in my RRC about ten years ago, I had an uneven idle that was caused by a leak of coolant into one of the cylinders. I could tell because all but one of the spark plugs were straw colored, but one was steam cleaned and absolutely pristine looking. Also, I had a little extra white steam at the exhaust on start-up on fall mornings.
I mentioned clogged injectors because my boss had that problem with his BMW X5 4.4. He took his injectors to Oregon Fuel Injection where they tested them before cleaning them, but two were too far gone to clean, so he bought a new set of eight.
Anyway, there are lots of potential causes for a rough idle, so eliminate each in turn before spending a lot on parts that may not fix the issue.
Scott
Scott
