Miss fire codes on a 1996
Old Mar 13, 2007 | 08:42 PM
allstarbiker592's Avatar
Default Miss fire codes on a 1996
I have been having alot of miss fire codes on my car. It is a 1996 se with 150000. What could be the reason it miss fires??
Old Mar 13, 2007 | 11:03 PM
okdiscoguy's Avatar
Default RE: Miss fire codes on a 1996
When is the last time you had a tune up?
Plugs&wires. Not sure if you have the coil packs, or straight distributor. Might be a faulty injector leaking too. I would start with plugs and wires if they haven't been changed recently. I think DiscoMike has a link for some good 8mm Magnacor wires. Also run a can of injector cleaner through every 3k to 5k miles making sure you are running premium fuel through at all times.
Old Mar 14, 2007 | 11:41 AM
So, as already asked, what sort of tune related work has been done on your truck, what fault codes are you getting, what octane gas are you using?
Mike
30more
Jun 20, 2012 12:19 AM
Buzz09
May 8, 2010 04:21 PM
tommytwotone
Oct 26, 2009 10:59 PM
mitsi88
Mar 26, 2008 08:51 AM
04DISCOINHR
Feb 28, 2007 12:05 PM
