Missing access plug on block?
I was finishing up replacing the crankshaft position sensor on my 99 D2 and looked up and saw a hole where I feel very strongly some sort of plug or access panel should be, I can see the ring gear teeth through the port. This is on the driver side looking back at the bell housing attaches to the block. I’ve attached a picture. Can anyone confirm what should be there and any ideas of how I might get ahold of a cover. I’ve taken a look at the RAVE manual but couldn’t find it.
JUKE179r (08-27-2019)
@greisinb Just water
- on a warm or hot dry day
- remove the plate
- put a bucket underneath
- if you want mix up a bit of dishwashing soap and hot water in a spray bottle and spray it in both sides - a squirt of dishwashing soap and the rest hot water will do
- If you spray give it 5 - 10 minutes
- Then just water from a garden hose both sides, or hot water form a spray bottle a bit at time you do not need to fill it
- empty your catch bucket between flushes
- Once it flushes clear leave everything open for at least 12 hours in the heat to dry out, then take for a short drive on pavement just to push some air through
- Seal it all up
JUKE179r (08-13-2019)
Just wanted to report back that I’ve installed the two missing grommets, it took longer to jack the truck up than it took to actually pop them in, that was a nice change! I also removed that access panel- there wasn’t anything of note up there so I didn’t clean it out. Thanks for all of your help!
