Missing bolt
So I was under the disco swapping out the swaybar links today and noticed a threaded hole without a bolt in it on the shallow end (towards the rear of the vehicle) of the engine sump. I have a feeling something is supposed to be in there, but maybe I'm wrong?
[IMG]
[/IMG]
[IMG]
[/IMG]
I assumed it was for a bracket to hold cooling lines or something. It definitely causes no leak. Maybe it is used on other models and not ours?
I have this hole too.
If it was drilled all the way through into the pan it'd be perfect for an oil line leading to a small turbo. Instead of how most aftermarket turbo kits just replace the oil pan bolt.
If anyone turbo'd a disco I would be impressed.
