Missing Front Drive Shaft
Did my first oil change on my latest rig, 2004 Discovery SE7. Only to discovery the Front Drive Shaft not present. I know how to get and in stall one but the bigger question is WHY?
Do these fail and people simply pull them?
Stefanas
Stefanas
Is the diff lock light on in the dash?
There could be some more serious reasons as to why PO removed the driveshaft... blown front diff, axle, center diff spider gears blown (causing it to be locked in CDL), among others
Is the hi-low shifter pushed to the left or right?
Get under the vehicle and make sure the two CDL switches are plugged in and working, the cable is attached, etc. I'd want to make sure I could unlock the transfer case before putting in a front D/S
