Missing grounding strap
Old Aug 18, 2024 | 01:51 AM
evil_goat's Avatar
Question Missing grounding strap
Do the 2004 Discoveries have a grounding strap connecting a head to the body of the car? If so, I might have lost it or it was missing. Will the car start with it missing?
Old Aug 18, 2024 | 06:28 AM
H20nSnow's Avatar
You need every ground strap or an equivalent. Even if it starts, not having it is sure to cause you issues.
Old Aug 18, 2024 | 11:24 AM
zski128's Avatar
I think the head ground strap was on 2002 and earlier vehicles. A quick search here might find the thread.
Old Aug 18, 2024 | 05:21 PM
mollusc's Avatar
Both my 2003 and 2004 have a grounding strap from one head to one of the bolts holding the heat shielding to the firewall. I made a second one for my 2003 to try and suppress some noise that was coming through the radio.
Old Aug 18, 2024 | 06:25 PM
JohnZo's Avatar
Max current goes through the starter, so best to have a direct ground from the starter to the battery (or near the battery). Also best to have a heavy duty ground from the alternator to the battery. If you have those, an extra ground strap is icing on the cake, but cake is fine without icing. Main principle is the engine sensors need a good reference ground to the ECM.
If the starter ground becomes open or corroded or loose, the current will find the path of least resistance, so some have burned up the E-brake cable that way.
Old Aug 18, 2024 | 11:08 PM
mln01's Avatar
Yeah, uh, all years of DIIs had the grounding strap connected from the rear of the Bank 1 head to the firewall. Your truck may start without it, but there'll be hell to pay down the road if it or some substitute is not in place.
It doesn't need to be the original, braided strap. A short battery cable will do the job too. Just don't kid yourself that it wasn't there or it isn't important.
Old Aug 19, 2024 | 12:29 PM
zski128's Avatar
Damn better check mine then.
Old Aug 19, 2024 | 09:44 PM
Discorama's Avatar
My 04 D2 has two grounding straps: one smaller on the drivers side to the firewall and one bigger on the passenger side to the body near the battery. If only the front one near the battery is not making good contact, the starter motor struggles to start the engine and battery won't charge well.
boranup
May 11, 2023 03:43 AM
jiklzzz
Freelander
Dec 22, 2022 11:45 AM
redwhitekat
Nov 10, 2015 11:16 PM
Jessicajw
Aug 25, 2014 10:30 AM
user 70820942424
Oct 25, 2013 08:43 PM
