missing thread
These recent changes suck. It used to be that all the most recently add or updated threads show up first. Now I have to scroll to the bottom and change the display options every time I enter the forum. Very annoying. I think the forum default has been changed to only show threads from the past 10 days rather than having everything available to just browse through. All this would be fine if the search function actually worked. Overall, I have to rate the new updates as terrible. The forum needs to go back to how it was before they started making "improvements".
For some reason it seems that the Discovery sub-forum is the only one having this issue. If you go into the classifieds or the Range Rover threads they're sorted properly!
I don't know what happened, but it is definitely a major PITA.
Try this...At the very top of the forum you will see - "Threads in Forum : Discovery: Click on the little pyramid to reverse thread order and see if that brings back your thread. I posted a question last night and could not see my thread until I reversed the order. Bad thing is, I have to reverse order every time I come into the forums to put them in time order.
If I wanted to do that much work I would find a job.
Reordering works to a point. The default thread option is showing to sort by thread name from oldest to newest. I am assuming it is sorting the tread names in alphabetical order.
