Mobil 0w40 motor oil
Old 09-09-2008, 11:16 AM
Switzer's Avatar
Default Mobil 0w40 motor oil
I am currently running 10w40 Valvoline Maxlife with no oil leaks and no burning of oil.
Is it a safe idea to switch to Mobil synthetic 0w40? I think it is worth the extra cost for the heat range and protection it provides. I switched my F150 to Royal Purple with good results and no leaks so I am inclined to try it on the Rover.
The Rover has 134,000 miles on it and runs great!
Cheers,
Pete
Old 09-09-2008, 11:25 AM
brooksa's Avatar
Default RE: Mobil 0w40 motor oil
I have used the Mobil 0W40 since Jan and have had no issues.
Old 09-09-2008, 11:33 AM
Switzer's Avatar
How many miles were on your Disco when you started using 0w40?
Cheers,
Pete
Old 09-09-2008, 11:54 AM
brooksa's Avatar
Somewhere around the 65k range
Old 09-09-2008, 11:58 AM
You are going to light on oil unless you are talking about running this weight in sub zero weather. Here is Colorado, I run Mobil one in a 5W/30 to handle the cold weather starts.
Old 09-09-2008, 12:01 PM
brooksa's Avatar
Mike, you are probably right on the "too light" but when it was time to change 0w 40 is what was available?? I know strange, so next go around will be 15w50 or so.
Old 09-09-2008, 01:32 PM
Switzer's Avatar
0w40 is going to flow better at low temperatures while protecting like a 40 weight at normal to high temps. A 0w20 oil would be too light. The 0w40 Mobil would be similar to the 10w40 I am currently running with the exception of better cold temperature flow characteristics. This is my impression at least.
Cheers,
Pete
Old 09-09-2008, 01:34 PM
Here again, alot depends on how cold you get in the winter.
I use 2 different weights, one for winter the other for summer and those Rockie Mountain trails.
Old 09-09-2008, 01:38 PM
Switzer's Avatar
I'm here in the Springs and don't expect lower than single digit temperatures. I like the appeal of the temperature range protection it offers as a year round solution. From what I've read the 0w40 Mobil 1 is their European formula which contains more ZDDP. Most motor oils now have 200-400ppm of ZDDP because of regulations while other motorists abroad get 800-1000ppm from their oil.
If anyone is interested read this page on engine oil.
http://www.carbibles.com/engineoil_bible.html
Cheers,
Pete
Old 09-09-2008, 01:51 PM
Those higher ZDDP numbers are in Mobil 1 15w-50 too.Thats what I use here in MI, year around. We get below zero for a couple weeks a year.
Quick Reply: Mobil 0w40 motor oil
