More Disco II problems...
Agh... this truck is going to be the death of me. Anyway, I was driving home and I hear the dreaded dings of death... look at my instrument cluster and it seems as if the truck still wants holiday season to still be here... being that it looks like a damn Christmas tree.
The bags in the back wouldn't air up... hence the auto leveling warning light...
HDC, ABS, and TC shouldn't have came on because the brakes have been replaced, as well as the drivers side bearing and hub.
So I pulled the bags off of the back and found two small leaks on the drivers side. Had those repaired.
Can anyone tell me where the auto-leveling sensor is??
Still have about $12k to pay on it..
I'll sell it for $8500 USD!!!!!
ok to start off, it is a very nice looking rover..so lets get it fixed. Before you start throwing coil spring kits at it go test the level sensor. On my 99 DII the sensor is a small arm that mounts to the frame and connects to the left rear radius arm. I can take a pic of mine if you need me to.
as far as testing the sensor, I assume the sensor is a potentiometer and the voltage will vary as you move the arm up and down.
