more temperature questions
Old 07-05-2014 | 11:14 PM
driftology's Avatar
Default more temperature questions
My 2000 disco has been running with idle temps hovering around 206 with running temps at 194. I install a motorad 180 thermostat a few days ago and now the idle temps are 204 and running temps 201. It seems like everyone else that has installed these has had bigger temp drops. Should I keep it in, go back to the stock thermostat or should I step up to the genuine grey rover one? I'm in California btw. It has been in the 80s.
Old 07-05-2014 | 11:52 PM
Dane!'s Avatar
step it up with the genuine 180 stat, its likely that you have a faulty motobad stat.
Old 07-05-2014 | 11:53 PM
mbruneaux's Avatar
I have seen the same as you with the cooler thermostat. Keep it, I saw 206 climbing a big hill with a trailer at 90deg ambient, running cooler without a "check engine light" is a good thing in the Rover.
Old 07-05-2014 | 11:58 PM
driftology's Avatar
I will have to see if I can get the genuine one in less than 3 days. I have a trip coming in 4. I was really hoping to see all the magical low numbers everyone talks about. I have to pull a small u-haul trailer and I just want to play it safe.
Old 07-06-2014 | 12:04 AM
Dane!'s Avatar
better safe than sorry. You might also have air in your system that's not bled out.
Old 07-06-2014 | 12:21 AM
driftology's Avatar
True. Well I will give it a couple days and see what happens.
Old 07-06-2014 | 11:43 AM
toofaroffroad's Avatar
I can only speak from my own experience. I have a motorad and it's great. I went from 205-215 down to 188-195. since installing my temp has never gone higher than 197 and that sitting in traffic for long periods. I also did a coolant flush and added purple-ice coolant additive.
Old 07-06-2014 | 12:38 PM
Richard Moss's Avatar
If you have idle temperatures higher than running temperatures I would get the fan clutch checked. It could well be that it has got a bit old and is not driving the fan properly. You may also have a faulty water pump - the one on my V8 had been damaged by the previous owner not using anti-freeze.
Here in the 120F+ temperatures of Abu Dhabi, my 2003 model was getting too warm when left idling but would cool down when driving. A new fan clutch took away almost all of the problem but I decided to do a pre-emptive change of the water pump and thermostat along with a VERY thorough flush of the radiator and now the temp stays rock solid at the right point regardless of what I do with the car. You would not believe the amount of crap tha came out of the radiator.
Old 07-06-2014 | 07:38 PM
driftology's Avatar
Did a pretty good flush when I did the thermostat. Would the pump fail with less that 40k miles. New motor was installed a few years ago. This engine has has long life green coolant since it was first started. Clutch seems fine. I will check it again. I think I will overnight a grey thermo and see what happens.
Old 07-06-2014 | 10:12 PM
xxdoylexx's Avatar
201 is well with in the OK range for your Discovery. Secondly, what a 180 degree thermostat does is open the valve to your heater when the coolant temp hits 180 degrees. If your heater is on, your temp will not drop. Now I may be dumb here but it is summer and the odds of your heater on are small.
Thus in a nut shell a 180 thermostat does not and will not affect the running temp of your Discovery.
Quick Reply: more temperature questions
