..:: The morning clicking noise situation ::..
Hello Roverers!
Happy to report that Disco has been fine after the fusebox swap, but in the past couple of weeks I've been hearing a clicking sound every morning that I start it up. Noise seems to come from the fusebox panel, so it may be a faults relay perhaps. Today I noticed that sound is a bit louder when I press the Brake to shift out of park; as a matter of fact, I now see that when is clicking, the lights on shifter blinks. After a while it stops clicking, and I don't hear it throughout the day, it only happens on the morning start up. Any tips as to which relay should I look into first? Thanks.
I have a video of the issue for you all to see:
Could be your XYZ switch getting ready to start acting up. I had a relay clicking in the same area when I changed gears, along with the classic blinking M/S lights and limp mode. I took it apart and cleaned up the contacts, loaded it up with dielectric grease and haven't had any more problems. Does it click when you move the gear selector?
adolfojbonilla (02-01-2022)
In any case, yesterday and the day before Disco started without doing this issue, I'll see today; so what I've thought was an everyday thing, seems now to be random.
I was wondering if any of Disco S2 SE owners like mine also hear a soft light "click" from under dash panel when pressing the brake to shift out of park under regular conditions. It is not comparable to the loud and louder clicking you hear on video I posted, which clearly shows some type of awkward behavior.
Any way, my Disco does have a faulty something, it just hasn't done it for 2 days in a row, so we'll see this morning. Thank you all.
