..:: The morning clicking noise situation ::..
Old Jan 31, 2022 | 03:46 PM
adolfojbonilla's Avatar
Default ..:: The morning clicking noise situation ::..
Hello Roverers!
Happy to report that Disco has been fine after the fusebox swap, but in the past couple of weeks I've been hearing a clicking sound every morning that I start it up. Noise seems to come from the fusebox panel, so it may be a faults relay perhaps. Today I noticed that sound is a bit louder when I press the Brake to shift out of park; as a matter of fact, I now see that when is clicking, the lights on shifter blinks. After a while it stops clicking, and I don't hear it throughout the day, it only happens on the morning start up. Any tips as to which relay should I look into first? Thanks.
I have a video of the issue for you all to see:
Old Feb 1, 2022 | 10:33 AM
mendenhall2's Avatar
Could be your XYZ switch getting ready to start acting up. I had a relay clicking in the same area when I changed gears, along with the classic blinking M/S lights and limp mode. I took it apart and cleaned up the contacts, loaded it up with dielectric grease and haven't had any more problems. Does it click when you move the gear selector?
Old Feb 1, 2022 | 11:58 AM
Thanks for your input. The clicking noise is similar and as loud as when turn signals are on. This happens only at morning start up, while Disco is idle, after a few minutes it goes away. Yesterday was the first time I notice the louder noise when pressing brake to shift out of park, like if it came from the shift lock actuator, and also first time I saw the lights on shifter blinking. Today the clicking noise was not present. No it does not click while moving gears, it only comes out as soon as I start the Disco for a few mins.
Old Feb 1, 2022 | 01:58 PM
mollusc's Avatar
Does your truck have SAI? If so, is it operating correctly?
The "only when cold" behaviour makes it seem possible that it could be related to that circuit.
Old Feb 1, 2022 | 06:55 PM
Thanks for your input Mollusc. Yes, it has SAI, and yes, it seems to be working fine. As usual, every morning when I start it, you can hear the vacuum do its thing, and once it goes off, is usually the time I shift out of Park, and start driving. It's been like that forever, so I figure it's fine. Occasionally I would hear the vacuum going on when stopped at a light, but usually goes off immediately. And yes, it seems to be an "only when cold behavior". Again, the clicking noise of a relay is what makes it noticeable.
Old Feb 2, 2022 | 11:46 PM
User's Avatar
Hmm, out of curiosity, are your brake lights going on and off whilst this is happening?
It could be as simple as the brake light switch.
Old Feb 3, 2022 | 06:20 AM
...thanks for your input, but I do not know. It only happens in the mornings, when I'm by myself, but I'll try to check if it does what you say, or anything else.
In any case, yesterday and the day before Disco started without doing this issue, I'll see today; so what I've thought was an everyday thing, seems now to be random.
I was wondering if any of Disco S2 SE owners like mine also hear a soft light "click" from under dash panel when pressing the brake to shift out of park under regular conditions. It is not comparable to the loud and louder clicking you hear on video I posted, which clearly shows some type of awkward behavior.
Any way, my Disco does have a faulty something, it just hasn't done it for 2 days in a row, so we'll see this morning. Thank you all.
Old Feb 11, 2022 | 11:53 PM
User's Avatar
When it is under 10-15 degrees my turn signals don't work until it warms up.
I wonder if it's a similar situation with the brake light switch Hahah
Old Feb 13, 2022 | 10:21 PM
...after I last posted on this thread, the issue had not repeated itself until Feb 10th ...with clicking noise from fuse box; Occasional shifter lights blink; no louder click when pressing brake to shift out of Park, as experienced last time; and clicking went away a couple mins after vacuum went off, as I was ready to drive off ...coincidentally, temp that day was in low 60's ...so yes, it crossed my mind then if colder temp could be playing a role ...after that day it hasn't happened again, and morning temps had been a bit warmer ...so I'll be looking into that as well. Thanks for your input.
Old Feb 14, 2022 | 07:53 AM
...for example, today's temp at startup was 63, and clicked.
