Motor Mounts?
Any chance you'd mind elaborating and describing exactly what to look for in the photos that shows the issue? I have to admit that I'm not familiar with the "telltale" signs and I'd love to be able to visually inspect my rigs and be able to know exactly what I'm looking for and be able to spot it without a lot of doubt.
DCDisco2 (02-16-2021)
Mounts...
Picture above, drivers side mount, you can see center rubber piece has seperated from the aluminum portion that mounts to frame rail. You can see a gap, top corner of rubber.
Picture above, passengers side, center rubber portion has seperated from steel plate that mounts to engine bracket. You can see how it has shifted back past the rear edge of steel plate.
To check them further, position a floor jack under oil pan, put wood block between oil pan and jack, lift gently...if the mounts are bad...a gap will be quite obvious.
The following 5 users liked this post by The Deputy:
DCDisco2 (02-16-2021),
DiscoID (02-16-2021),
gulfstream69xr7 (02-16-2021),
JUKE179r (02-17-2021),
Richard Gallant (02-18-2021)
Originally Posted by whowa004
buy a shorty 18mm ratcheting wrench to make the driver side easier....not super hard but one of the driver nuts is a pain.
A ratcheting combination wrench is not necessary, but it does make life a bit easier. It's most important that you have a shorty/stubby 18 mm combination or box-end wrench, ratcheting or not.
