Motorad 180 Thermostat failing, not winning...
Old May 19, 2016 | 11:00 AM
Motorhead1's Avatar
Default Motorad 180 Thermostat failing, not winning...
I installed this Motorad 180 T-Stat a couple/few years ago, long before any bad mouthing of this part had started. All has been well with temps staying between 194-198. When ambient temps reached 110* in the summer, I would occasionally see heat soak of 208* (after hot start ups). I've been noticing small temp spikes lately just running around town in cool weather, so I finally ordered the grey Genuine LR 180 T-Stat, installed it yesterday. As you can see in the pic (kinda), the black rubber seal inside the Motorad t-stat was coming apart!! That black rubber gasket is supposed to be seated down inside the t-stat. This is looking down inside the "pump" port of the t-stat. My new t-stat is running about 8-10* cooler already. Awesomeness. Thought I would share this...
Old May 19, 2016 | 08:28 PM
coors's Avatar
Search the forums you'll come across horror stories - Motorads are garbage. I experienced the same symptoms as you with dislodged rubber seal. Genuine 180 is the way to go if you intend to maintain the factory designed cooling system.
CollieRover
Jun 18, 2020 01:05 PM
cosmiccharlie
Jun 5, 2013 10:09 PM
mx468
Apr 29, 2013 08:08 PM
MC04DII
Dec 5, 2012 10:14 AM
Spencerfitch
Oct 30, 2012 07:14 PM
