Motorcycle carrier recommendations
Old Oct 30, 2007 | 09:50 PM
Willie 00D2's Avatar
Default RE: Motorcycle carrier recommendations
I haul a Rm 250 on a 80lb. carrier and it does make the back sag, also make your headlights aim high. I think I will get some airbags like Fonzie.I hooked up some taillights on my carrier because the carrier was in the way of the bumper turn signals. I like to put a extra strap to the spare tire carrier and hooked to the handlebar just as a safety strap. Hey Fonzie let us know how you like those airbags onyourDiscovery.
Willie
Old Oct 30, 2007 | 11:09 PM
Fonzie's Avatar
I know, it looks like abuse, but don't worry I'll beInstalling the airbags before I try this again. I'll post up "After" photos so we can see the difference the airbags make to the attitude of the rig.
My camera phone at night isn't the best quality:
[IMG]local://upfiles/8144/3326054D273641228B84AA8FF0ECC5F4.jpg[/IMG]
Old Oct 30, 2007 | 11:10 PM
Fonzie's Avatar
...and onefrom the rear:
[IMG]local://upfiles/8144/279A72BB36BC44CDA4879D65F421469A.jpg[/IMG]
Old Oct 31, 2007 | 11:41 AM
marcwestbmw's Avatar
Looks good. I can't wait to see the after. If you're real motivated, you could do a photo documentation for the rest of us.
Old Dec 5, 2007 | 10:06 PM
Fonzie's Avatar
OK, here's the "After" pic. I've actually had the AirLift installed for a few weeks now, but today was the first time I had the bike back on there again for another trip to the dealer. The photo was taken at almost the exact same place and time of day...makes comparing easier.
As you can see there is considerably less sag, and it's a whole lot more stable on the freeway. But you still have to be more careful and aware than when driving without the extra load as the steering is lighter. Around town you forget it's there.
[IMG]local://upfiles/8144/FA4D86BB992046A681E6ACE6FCA5D769.jpg[/IMG]
Old Dec 5, 2007 | 10:12 PM
Fonzie's Avatar
Sorry, no time to do a full on documentation...it really doesn't need one though, since it's so easy to do and the instructions are decent enough.
I did snap this one for ya though Shows one airbag installed and one of the new OME shocks I installed at the same time.
[IMG]local://upfiles/8144/8CE62A062BB2498F9C786E4291BDBA2A.jpg[/IMG]
Old Dec 5, 2007 | 10:16 PM
Fonzie's Avatar
And another from the rear:
[IMG]local://upfiles/8144/2D1AAE2BEBF847DEAAD62BCA7AC074D7.jpg[/IMG]
Old Dec 6, 2007 | 07:42 AM
Fonzie,
Thanks for the follow up. Looks great. I've got to get that set up.
It would be perfect for the Trans America Trail. You could bike it or drive it, depending on how beat you are.
Old Dec 6, 2007 | 06:35 PM
Looks good Fonzie. I need to get a set on mine. How much pressure do you put in the bags?
Willie
Old Dec 6, 2007 | 08:56 PM
Fonzie's Avatar
You can set them anywhere from 5-35psi max. I inflate them to the max 35psi since my bikes are quite heavy. You must keep a minimum pressure of 5psi in the bags at all times to prevent them from getting pinched by the coils. If you get the optional compressor, it comes with a regulatorswitch that will automatically kick on thecompressor if the pressure ever drops below 5psi andwill also kick it off once you reach 35psi, to prevent you from overinflating them.If you're thinking about installing yourself, it's really easy, you don't even need to remove the coil springs. Just disconnect thelower end of the rear shocks and lower the axel to full extension...there's plenty of room to squish the airbag inbetween the coils. The procedure is covered in the instructions.
