moving on up
moving on up
Hi guys
Mistakenly I put my question in the range rover section,guess this is what rovers do to your head.Anyway I am planning on buying a2003 Disco HSE with 38000 miles on it.Having a wonderful experience with my 98 Disco ,can I expect the same of this puppie?Hope you can help out as always.Special hello to Disco Mike,thanks for all your help and knowledge.
on
RE: moving on up
I have a 2003 SE (No air suspension), and it is fabulous. It drives great. It was raining cats and dogs today, and roads were soaked and I couldn't tell, because I was in a Disco II. Off road, I don't know yet, but on some trails in the woods it has done well. A lot of folks have ripped that air suspension out and put in a coil system because the sensors for that air suspension get destroyed, bladders burst and/or leak, etc etc. Just keep it in mind.
Good Luck!Feel free to ask any questions.
RE: moving on up
Only one thing to look out for on the 03's. First year for the 4.6 and known in early models to loose oil pumps. I hear the performance gains are noticable in the 4.6, plus you get all the bells and whistles of a D2. But along with that, you get the 3 amigos and lose the locking transfer case. I foyu do any wheeling, go for an 04. They have the locking diff again, and in a lot of people's opinion are the best ever made. Oh, and on the above comment about air suspension- I hear the ride is a lot better than the coils, but a little expensive to maintain.
RE: moving on up
I love my 03 and I use it as a daily driver with some light to moderate off-roading in sand with a little snow driving in the winter. If I did really heavy off-roading I would probably want one with CDL capability just in case, but I can't imagine needing it for the way I use my Rover because its 4wheel drive system is amazing as is. I pretty much agree with what the others have said already, and I guess it all depends on how you intend to use your Rover as to which model you should be looking for.
RE: moving on up
I hate misleading post like this about SLS.
"I have a 2003 SE (No air suspension), and it is fabulous. It drives great. It was raining cats and dogs today, and roads were soaked and I couldn't tell, because I was in a Disco II. Off road, I don't know yet, but on some trails in the woods it has done well. A lot of folks have ripped that air suspension out and put in a coil system because the sensors for that air suspension get destroyed, bladders burst and/or leak, etc etc. Just keep it in mind."
The SLS system is good, if the bags start leaking, which they will, yes you have to change them, but you also have to change out the coil springs as they start sagging. If anyone with an SLS issue uses common since they are easy to maintain, and I have to tell you with nearly 100,000 miles on mine I have had to put on new air bags, but the truck rides better on and off the road.
