mpg drop
Old Jun 3, 2014 | 11:40 PM
ninjaff21's Avatar
Default mpg drop
So i have had a sudden drop in MPG i use to have a misfire but the code cleared itself seems odd to me. i have bank 1 sensor 2 no activity on my o2 sensor. Can this affect MPG greatly? The O2 sensor is currently covered in oil from an oil leak that i can't seem to find and its all over the connector also could the 02 be fine and it just be the connector and if i replace the O2 will it just die again because of the oil leak?
Old Jun 4, 2014 | 05:08 AM
jeffh's Avatar
change you upstream O2 sensors clean the area really well before you replace and use the Dielectric grease on the connections, this will help in protecting the connectors from grease, dirt and water. Also how old are your plugs and wires
Old Jun 4, 2014 | 07:31 AM
drowssap's Avatar
Can this affect MPG greatly? YES
Old Jun 4, 2014 | 10:57 AM
ninjaff21's Avatar
Wires haven't been replaced since i own it records show they were replaced at 100k i replaced the plugs at 126k miles with NGKs
Do i need to replace both sensors at the same time
Old Jun 4, 2014 | 11:01 AM
jfall's Avatar
You are absolutely crazy to run around with bad O2 sensors.
You want to ruin your cat converters?
You are my friend ON THE WAY to doing this.
ALL the gas that is dropping the MPG is going into the cat converters and superheating them.
Please STOP driving it and fixing it.
You are also polluting the environment more.
Sorry to be harsh - but this is true.
Old Jun 4, 2014 | 11:02 AM
ninjaff21's Avatar
Oh wow i had no idea i was wondering why there was a heat buildup in my floor board!
Old Jun 4, 2014 | 11:11 AM
ninjaff21's Avatar
can i replace just one or do they need to be replaced in pairs
Old Jun 4, 2014 | 11:18 AM
drowssap's Avatar
replace all 4 you can get them on amazon for around $50.00
Old Jun 4, 2014 | 11:26 AM
ninjaff21's Avatar
I can't wait on shipping so I'm having to buy them local being its my only car i have during the day and i have to use it to get to work. can i save money now and only get the front 2
Old Jun 4, 2014 | 11:41 AM
dusty1's Avatar
yes do them in pairs.. ups then downs. best to do all 4, but anything is better than notta......
