Muffler Front Flange Studs
Hi guys,
While removing the main mid muffler/silencer, the studs on the front flange (flange with the 2 bolts without gasket) sheared off. Does anyone know how the studs are fitted into the flange? Are they threaded or welded in place?
I want to remove the studs and replace with bolts but want to know the best way of removing the old studs. I am hoping that I can get around drilling them out , especially since it seems the flange cannot be removed from the y pipe to do it...
Any suggestions?
Thanks for your help.
Kevin B
2004 DII
Any suggestions?
Kevin B
2004 DII
The following 2 users liked this post by 0304Disco:
cvhyatt (01-28-2020),
Sixpack577 (01-27-2020)
I drilled the stud heads off and used a mallet to whack the threaded side until they popped out. Would be easier to drop the Y pipe as any whacking could mess up the manifold to Y studs/ gaskets. I then replaced the studs with some zinc bolts and nuts so I didn't have to worry about rust again. My only issue was that I over tightened the new bolts and had to back them off a little bit.
