Multiple misfire?
Old Mar 20, 2024 | 01:43 AM
  #51
Helias86's Avatar
Not sure if the MAF reading is off or not, nor sure how many pounds per minute is normal.
But one o2 sensor seems like it has low voltage??
Old Mar 20, 2024 | 05:14 AM
  #52
Extinct's Avatar
You can't really tell anything from digital data from an 02 sensor, you need analog data as shown in this video:
$15 elm327 bluetooth module and the free torque app or similar that will chart analog data. You should see the 02s cycling regularly.
This is the best coil/wiring diagram in imho
Old Mar 20, 2024 | 07:28 AM
  #53
mln01's Avatar
Extinct, the YouTube link does not work.
Old Mar 20, 2024 | 02:08 PM
  #54
Extinct's Avatar
Thanks for the heads up, fixed!
Old Mar 20, 2024 | 02:40 PM
  #55
Helias86's Avatar
Originally Posted by Extinct
You can't really tell anything from digital data from an 02 sensor, you need analog data as shown in this video:https://www.youtube.com/watch?v=UNzi30G2_Kk $15 elm327 bluetooth module and the free torque app or similar that will chart analog data. You should see the 02s cycling regularly.
Well, It is my current understanding that the o2 sensors for example, will sit at certain voltage values if good, and another value if bad. What I find interesting, is the huge disparity between the two voltage values of the front sensors.
Old Mar 20, 2024 | 02:50 PM
  #56
Extinct's Avatar
Absolutely incorrect, you need to watch the video.
Old Mar 20, 2024 | 02:55 PM
  #57
Helias86's Avatar
oh! Ok! Lol
Been driving all morning, so I'll watch when I get home. Thanks so much!
Old Mar 21, 2024 | 09:09 PM
  #58
Helias86's Avatar
So... new o2 sensors, and a new MAF sensor, all Bosch units. Misfire persists. Interestingly enough, my intake temps are now showing 40* BELOW 0*f lol
What gives??
Old Mar 21, 2024 | 11:21 PM
  #59
JohnZo's Avatar
-40 deg F is the minimum value of the sensor range. It probably means the sensor is disconnected, or otherwise open circuited (e.g. wire is broken or cut or disconnected). I would get that temperature value (on the Torque app) when one of the wiring splices on the ground wiring became loose. Took a good bit of detective work with the wiring diagrams to track it down.
Maybe time for a new thread?
Old Mar 21, 2024 | 11:22 PM
  #60
Helias86's Avatar
It is still causing misfires.
