Multiple Misfires.....??????????????
Are you sure it isn't electrical? Is the engine ground strap secure and the nut and bolt tight? Also there are ground wires (bright green on mine) exiting the back of the upper intake that are usually bolted to the bottom bolts of the coils. They are part of the injector harness. You should be able to barely see them with a flashlight if you hold your head just so.
When the weather changes vacuum leaks can sometimes get better and worse, if they are small.
I have not seen any ground wires in the vicinity of the ignition coils so I will look into that this weekend and see what I find. If that's the problem you'll be my new best friend, this has been going on what feels like forever.
Thanks
Rob
Don't feel bad, if the diagnosing and repairs were easy you would be driving a Chevy. I'm still dealing with random P1174 and P1171 codes despite a new MAF and PCV valve. I have sprayed carb cleaner and get no change, and smoke tested it. I think that some times you just have to chuck parts at it. Stupid but at least your not paying for labor.
So disc oh no,
Are you saying that a drop in fuel pressure will trip lean codes? I would have thought that a clogged injector would lead to a misfire for a specific cylinder. If I understand your thinking, a general drop in fuel pressure will trip a "generic" lean code like 1171 and 1174? So it might be the injector rail or general fuel pressure? With pressure being an issue, could it also be the fuel cap is not creating a proper seal?
So disc oh no,
Yes, low fuel pressure can cause these codes. Usually, with lean codes on both banks, I check for vacuum leaks first. If I don't find anything there, I go after fuel pressure. That is not to say these are the only two things that can cause these codes. They're just the most common.
Clogged fuel injector generally means that it is spraying rather than misting. I don't think that would affect fuel pressure, nor would a non functional fuel injector. The pump would just have an easier time maintaining pressure with a non functional one.
I will have to get a pressure gauge to see if I can get a read on the fuel pressure. That seems like a difficult test to do. Can it be done with the upper plenum removed, Im not sure I can get to it otherwise.
thanks
Still working the issue, while trying to fix electrical problems
thanks
thanks
thanks
