Must have broken something while installing water pump
Old Jun 14, 2022 | 08:07 AM
RoverMasterTech's Avatar
Its the timing cover gasket leaking. Was probably leaking before you took the water pump off.
Old Jun 14, 2022 | 08:28 AM
SWM's Avatar
SWM
The leak I saw was from the water pump directly but it was a couple table spoons per heat/cool cycle so it would have been hard to see if the source was both. This leak is more substantial and consistent; especially considering its a constant drip even before pressurizing the system. Maybe by removing and installing the new water pump made it angry.
I guess my plan of attack is to first reinstall the 3 long bolts with silicone and see if it slows/stops then clean it up. If it's still leaking behind but not at the water pump it will be easier to see now. If that's the case I'll have to attack the timing cover. If it is the timing cover do I have to worry about getting coolant in the oil over a short drive?
Tumbler
May 23, 2021 12:01 AM
clint70
Oct 22, 2015 09:08 PM
Helper
Dec 14, 2010 08:18 PM
AussieDefender
Defender
Oct 4, 2010 03:10 AM
doddsy
Jun 29, 2009 06:02 PM
