My $500 Westminster
Got lucky at Pull-a-Part as a 2000 D2 was dropped off the day before and didn't appear to have anything removed yet:
So I got everything I came for, including a mostly not-cracked windshield cowling to replace my disintegrated one:
...and a few other bits I needed, including a fuse box cover, third brake light cover, bleeder screw neck, side repeater, three wiper arms, air pump and window switch. All for $65!
You've done an outstanding job on your Dll so far, very impressive.
Me, I'd scarf up those headlights off that wreck...they look pretty fog-free...and you never know when a rock or branch is coming your way. And it never fails...if you actually had to have them...you'd get bent over.
EDIT: And...grab the cup holders if they are available...someone is always looking for those.
Brian.
Brian.
Brian.
Brian.
Edit: I'd assume the fogs are worth something to someone, correct?
Cool. I plan on swinging back by this week. If I make it by and it's there, I'll be sure to snag it.
If you manage to grab it -- and you don't mind doing so -- could you also pull the plastic corner finisher above the windshield on the passenger side? It's the bit that slides into the drip rail and curls around, above the A pillar.
