My coolant overflow tank keeps peeing
Old Jul 30, 2017 | 06:05 PM
OffroadFrance's Avatar
It seems like the rad cap is not working OK. Borrow a new or used one from a kind hearted dealer and try it and if the problem is solved then buy a new cap.
Old Aug 1, 2017 | 08:16 PM
Casey McManus's Avatar
So the new cap seems to have done the trick (knocks on wood). I drove it to O'Reilly and had the same gurgling and hissing, got a new cap, put it on and drove home, no gurgling, no hissing. I've been driving the last few days in 100+ degree heat and it's been running well. AC is blowing cold and no waterfall noise. I topped the coolant off in the tank while cold, and it seems to return to the same amount after cooling back down from a drive. So barring any internal exhaust gas leaking into the system, it all seems to be doing well.
Thanks for all your help!
I'll update if something else essplodes.
Old Mar 19, 2020 | 03:23 PM
Vai2kdna77's Avatar
Hi Casey- I have a 2001 disco 2 and wanted to know what size hose you used for the expansion overflow from radiator? My plastic garbage has cracked (installing battery) and now I am pissed beyond belief. Please let me know tube size and hose length! Looks good!
Originally Posted by Casey McManus
So I just replaced the majority of my cooling system. Radiator, water pump, upper T hose, thermostat, expansion tank cap, the hose from the engine block to the expansion tank, and serpentine belt. I'm not having any more leaks, but I am having an issue with the rover peeing from the expansion tank after I turn the engine off from a drive. I'm hoping it's just as simple as a new expansion tank, but what else could be the underlying cause? Why am I getting that much pressure in the first place?
Here's a video of it doing the stuff.
https://www.youtube.com/watch?v=GuNo0qzLq4o
Also, background history: I had the head gaskets replaced a couple years ago by a L.R. specialist shop and it hasn't overheated since. I did these changes due to water pump bearings out and leaks. So I don't think that should be the issue.
ewatk
Jul 9, 2020 05:17 PM
bmeier
Jan 11, 2017 09:04 AM
junya
Aug 12, 2011 08:24 PM
bigfun
Dec 13, 2007 04:23 PM
